WildWesfishermen
Thread starter- Joined
- May 25, 2011
- 11
Hello All,
I recently picked up a 12 foot 1961 SeaKing Aluminum boat with a Sears Gamefisher 7.5HP aircooled outboard. I have been having trouble getting the motor to run effectively. The person I got it from said the motor had some water damage but didn't say where. I begin looking into the carb thinking that he ment that there was water in the fuel. I replaced the Fuel pump element i.e the duckbill and made a new gasket for the carb to the block. I also tried cleaning the carb out before reinstalling. I then noticed that I did not have enough spark maybe no spark at all. The motor also had very low compression around 30lbs. I then pulled the flywheel off and replaced the points and condenser making sure that I put in back in the correct timming and set the points to .020 when they break. I started to get better spark. I then sprayed some 50:1 fresh mix into the spark plug hole and tried to start the motor after several tries the compression went up to about 90lbs and held for over an hour. I continued to try this and it fired over and ran for a little while but appeared to be flooding so it died. I left it alone for a couple of weeks and then tried again and got it to run again a little bit but still died and still look like it was flooding. I saw gas coming from the top weep hole on the carb. I then researched some of the post and saw were Mrcrabs said that the duckbill should be at a 45 degree angle from 1 to 7 oclock. I pulled the carb off and fixed the orientation of it and tried again and now it will only fire for a quick second and not stay running like it is starving for fuel. I am still wondering if the carb is still not working correctly or if maybe the coil is bad and still not producing enough spark to fire over since it seems as though the condenser and points were bad to begin with. I thought about trying to retrofit a new coil spark system on it but do not want to put more money into it then what its worth. My model number is 217-586752 which from Mrcrabs is an eska 7.5 motor built in 1985 for Sears using Tecumse(spelling) parts.
