Sealant Question
scutly
while installing my new bilge pump i knocked my in hull hockey puck style transducer off. what is the recommended glue/sealant for reattaching?
Bob_VT
Re: Sealant Question
3m5200 is permanent or 3m 4200 if you intend on removing it
seabob4
Scutley,
If your transducer is the type that is filled with mineral oil, make sure you apply enough 5200 so that when you press down on it, you get good squeeze out all around the base. If not, your fluid will leak out...
