seal help
huntingdeer
1987 alpha one with a 305 mercruser
I replaced the bellows and now my question is their suppose to be rtv on the seal where the whole outdrive connects to the plate on the transome? i put some their and its leaking.
achris
More fish than mountain goat
Re: seal help
The bell-housing gasket should be put on dry. Putting any sealer on it may allow it to slide when the pressure is put on it....
Chris........
huntingdeer
Re: seal help
yea it slid and now i got to replace it again!lol im afraid im going to brake the drive if i keep pulling it out.This is the 3rd time lol.
achris
Re: seal help
I wouldn't worry about that... I've had my drive off and back on again about 20 times. 3 times in one week once... :facepalm:
You ain't gonna break it!
Chris.....
huntingdeer
Re: seal help
how do you get it on and off? Mine is really hard.I have to pry it off and then sometimes ive had to hit it with a hammer:(Ive put lube on it but no luck lol
ktbarrentine
Re: seal help
Did you check your drive alignment? It can be difficult to get off and put back on if it is out of alignment. Also, if you have grease on the drive shaft where the two O-rings are (just need a slight bit of oil smeared on there) it can cause issues on reassembly. I also put 2-4-c on the barrel of the drive before install. I glue the large rubber O-ring in with bellows adhesive, keep the water passage O-ring in with a glob of grease in the recess.
If your drive gasket (the paper one) has been "glued on" inappropriately in the past, it can also make it hard to get off.
huntingdeer
Re: seal help
I really dont have the money to buy the aliment tool right now.
ktbarrentine
Re: seal help
That's too bad...:grumpy: Less than 50 bucks on Amazon or Ebay.... and well worth it. If indeed your problem is because of poor alignment, then you could be looking at spending alot more when your coupling goes. Alignment needs to be checked each time you pull the drive.
achris
Re: seal help
Here's a video of me removing my drive. If yours doesn't come off this easy, there is something wrong. Like the man said, get yourself an alignment bar, or you'll be paying a lot more to fix the damage caused by a mis-aligned engine.....
Removing Alpha drive
Chris........
achris
djmakko
Re: seal help
Mine comes off easy, same drive Alpha one, and i check the aligment everytime , aligment tool is money well spend.
Chris, if you remove your drive that often do you replace the gasket everytime? or reuse the same mine breaks everytime.
achris
Re: seal help
..Chris, if you remove your drive that often do you replace the gasket everytime? or reuse the same mine breaks everytime.
Oh dear.... Is there somewhere I can hide from that question??? Please.....
OK... By the book... A gasket should be changed every time parts are separated.
Now, (I'm not saying this is what I do ;)) if the gasket is in good condition there is a possibility that it will 'go around again'. If the parts are not subject to excess stress during normal use, or the gasket hasn't been danaged in the removal process, then a user may reassemble the parts without the required new gaskets.... If the user does this, it is his own assessment and risk....
Main overriding rule.... IF IN DOUBT, REPLACE ALL GASKETS ON DISASSEMBLY....
Chris.....
huntingdeer
Re: seal help
Chris.....
ok im going to buy it.New question i have a loud clicking/rattling noise if i crank it up on the hose pipe.When it gets in the water the sound goes away.could it because its out of alignment?
achris
Re: seal help
Could be an out of adjustment lower shift cable, or shutters rattling...
Chris.........
