SEAGULL FUEL SYSTEM
nautico 19
WANTED TO KNOW ANY ONE OUT THERE WITH A SEAGULL NAUTICO. IF YOU EXPERANCED ANY PROBLEMS WITH FUEL, SYSTEM, TANKS.
PHILRAJOTTE
Re: SEAGULL FUEL SYSTEM
How old is the boat? Is there ethanol in the fuel that you are using?
nautico 19
hull is a 99 tanks are 32 gal located in hull below water line. Have 50 d tohatsu engines both having lack of fuel at high rpm wondering if the fule pumps are too week to lift fuel 2' to engines?
argyrost
Yes, I did. Check the fuel line near the gas tank. you have to take out the secal flex and lift the gas tank cover. The fiber glass on my boat was not cut back far enough. In rough seas, the tank would move a little and it slowly chafed the fuel line. I'm lucky that I didn't blow the whole thing up because of the fumes building up in the back compartment. Call me if you like at 301-526-4167. I wouldn't run the boat until you check it out.
Tassos
