seafoam chrysler 90hp
72INVADER90HP
I 1975 chrysler 90hp and it has never had seafoam used on it. I bought some deep creep from Seafoam. would yall recomend useing it.
Matthew A.
Re: seafoam chrysler 90hp
SeaFoam is an excellent decarbonizer. Use caution though when spraying it in intakes with the motor running. Use short bursts as opposed to long bursts while spraying contents into carb intakes. I have been advised that long bursts may not provide sufficient lubrication to crank and rod bearings. Possibly causing engine damage or premature wear.
72INVADER90HP
Thanks I will remember that. Do I have to take the boat immedately to the lake or can I let it sit for a week or two? And how much for a gallon of gas?
