Sea king 3hp outboard mint need year
ruintoit
GUYS I JUST GOT A SEA KING 3 HP OUTBOARD FOR MONTGOMERY WARD THAT SAT IN A BARN FOR 40 YEARS GOT CARB TORN DOWN AND PUT TOGETHER WITH NEW GASKETS - CLEARED UP ALL THE GEL AND CUT THE FUEL FILTERS SO THEY ARE ALL TIGHT, FIRED UP ON THE FIRST PULL THIS THING ROCKS, TURNIN HEADS IN NEWPORT RHODE ISLAND. IT WAS MADE BY GALE AT THE OLD OMC PLANT BUT CANNOT MATCH MY SERIAL AND MODEL NUMBERS TO FIND OUT THE YEAR SERIAL NO; 314922 MODEL NO : 84GG9009A any help, any 1 ?????
DOES ANYBODY KNOW MORE ABOUT THIS MOTOR AND WHAT KIND OF MIXTURE FOR GAS??? I WAS TOLD DO 1/3 PINT TO 1 GALLON OF GAS
northwoodslivin
Re: Sea king 3hp outboard mint need year
You would probably get more help if you didn't yell "use caps" Not sure but sounds like a 60's motor, I had an old 68 johnson 3hp, good old motor. I think the mixture for yours is 24:1
bktheking
I show a 84GG9007A from 1948-49 and a 94GG9009A 1949-1950, your Model is one of them just not sure what one you have, that should give you a rough answer.
I have a 51 Viking which was the same era, the manual calls for 1/2 pint for 1 gallon of gas, that would be 16:1.
bktheking
Suspect your motor looks something like this:
Just not in primer garb.
1946Zephyr
It's alright....don't sweat the small schitt. I'm willing to bet your motor is a late 50's motor. Like BK said, I think 16:1 is a good mix to run in it.
The coil is the same as the type as what would be used in any OMC, from 1951 on. Same with points and condensor. Water pump will be a tear drop type though, which is different from most OMC's.
F_R
84GG9009A is the model number. Monkey Wards makes it easy. The numbers before the GG are the year---reversed. So, 84 reversed is 48---1948.
lindy46
Heh Heh - Monkey Wards, F_R, you're dating youself;)
ruintoit
you would probably get more help if you didn't yell "use caps" not sure but sounds like a 60's motor, i had an old 68 johnson 3hp, good old motor. I think the mixture for yours is 24:1
yeah i wish i could dog spilled coffee on keyboard no more regular just high test for ya can you handle it? Thanx for the info you rock the world
ruintoit
bk are you the king ?
nope doesnt look like that it has no cord you have to tie a knot a give her a pull starts first time
what is the sequence for storing her for a couple of days ?
1 shut off petcock and shut off vent while it is running then let it run dry and stall? please lemme know what do you do?
mine is brick colored
thanx bk
ruintoit
ruintoit
thanx dude
you the man but how supreme are you?
enquiring minds wanna know
got a different comp no more all capppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppps 0oh damn the p is sticking
thanx
ruintoit
ruintoit
thanx dddddddddddddude it all runs good now, so 16 1 from now on outboard tcw synthetic i hardly smokes gonna get lower unit done up with right stuff too. thanx again guy i bought it from did points and coil but needed rent $$$$ got it for a cnote
