Hello everyone,
I would like to start off by saying great site. I have been looking around on here for some time gathering info from other post and it has been very helpful to me.
I have a Sea King 15 GG18737d 1962. I just got it with the purchase of a jon boat. I can not seam to get it started. Here is a list of things I have done and checked.
Carb opened and cleaned. (Did not replace any parts just cleaned).
Adjusted High speed to 1 turn out
Adj low speed to 1.5 turned out.
Fuel mix is 32:1 w/synthetic
new primer ball and fuel lines.
compression is 90psi and 95psi
checked spark with remote plug
got tired of pulling so I removed to housing and tryed starting with a drill.
Cranked it with the choke out for a while with throttle position in start.
Pushed choke in with throttle position at start and at idle.
choke in and manually pulled throttle to full throttle (incase flooded).
I am noticing fuel coming out the exhaust (that tells me fuel in getting through)
I am usually pretty good with engines. I do not know were else to go. I have a repair order for some maintance done in 2006. The repair order states they replaced the fuel pump, spark plugs and serviced the lower unit.
I think that you have all the info I have. I am stumped. What am I missing?
Thank You for any help,
Greg
Greg
