Sea Hunt leans to left under power?
Starman
I have a 2005 19' Sea Hunt center console with T-Top and 115 Yamaha 4S. The boat leans a little to the left under power. When I bought the boat it had a fin on the motor. I took it off before I drove it so I don't know if that would help? Could it be the T-Top?
Thanks
xjcj3a
Re: Sea Hunt leans to left under power?
torque from the prop can cause it, if your sitting level when just sitting on the water. then i would think its torque
cr2k
Good idea to leave the wing on for your first run. Then take it off. Now you will have to put it back on to see if it was there to cure the list to Port.
Most likely torque from the prop.
tnduc
More than likely the torque of the motor. Try trimming the motor up as you are under way. Keep an ear on the motor- if you hear the prop "howl" you have trimmed up too far.
