bigmikek
Thread starter- Joined
- Jun 18, 2013
- 79
My mercruiser 3.0 alpha 1 4cyl was over heating at low rpms. The water pump was making noises so I took it off and replaced it with a new one, Finding one is another story. Thinking that my overheating problem was solved proved wrong. The water pump did need replaced and the new one sounds great but the overheating problem remained.
So I got to thinking that maybe there was some blockage in the intake in my SE 106 outdrive.
I removed the insert screw and nut and removed the starboard and port inserts and there lay a 1/3 inch x 1 inch portion of one of the impeller fins.
Removing that and reassembling, I went to see if things were any better. They were not.
My guess was that the intake was restricted when the suction drew the portion of the impeller fin up toward the hole above the inserts and sort of plugged up that hole. Higher RPMS were drawing enough to keep the engine cool but low RPMS were restricting volume of needed lake water.
If part of the fin is missing, I am sure I need to replace the impeller with a kit anyway, but I am hoping that a new impeller will remedy the over heating problem.
I suppose for my own curiosity, I want to believe that a damaged impeller will cause an over heating problem in low RPMS.
Is this generally the case? Is this what is usually an indication of a damaged or non functioning impeller? The loss of cooling in the system? I think my water pump was doing all the work? Am I correct in my thinking. Thank you!
