Scott Atwater 5hp 1955 impeller replacement
Gbrad
I've read everything I can on the forum about this Brand motor and the issues with replacing the impeller. Can someone tell me exactly where it is located? I tried to drop the lower unit but didn't get very far after removing the 10 screws at the top and the 2 crews by the mount springs. It did separate a little but not enough to see the 2 impellers since it is a Bail-A-Matic. I took off the plate that the spark plugs are screwed into and found nothing then took off the other place on the where the spark plug wires come across and also nothing. It has to be under the foot if I can figure out how to get it completely off. Does anyone happen to have a PDF version of that motor diagram?
