Scored sleeve... Need to know why.
TBarCYa
Hello again. I am disassembling the powerhead in my 1981 Evinrude 115 because one of the cylinders (number 2) is scored and I'm trying to figure out why this happened. The rings are in tact (not broken) which leads me to believe that there was either debris in the cylinder or that it was lacking fuel. I am guessing that it was debris because the crankshaft seal ring between the number 2 cylinder and the main bearing is broken and could explain the debris. Since the scoring goes the entire length of the sleeve, I believe that the debris was under the rings which makes sense because that's where the crankshaft seal ring is located. <br /><br />My main question is whether there is anything that would cause a single cylinder in this engine to not get fuel?? It makes sense that the seal ring broke and let debris into the crankcase for the number 2 cylinder which scored the sleeve but just to cover all bases, is it possible for only that cylinder to not get fuel??<br /><br />Another thing I noticed is that the number 4 cylinder has a broken ring. The sleeve is in excellent condition, but there is about .75" of the lower ring that is missing. <br /><br />Any suggestions on how this may have happened or advice on how to proceed is greatly apreciated. <br /><br />Thank you.
JB
Re: Scored sleeve... Need to know why.
Each cylinder on your engine is "fueled" by its own carb throat and jets.<br /><br />A clogged jet or other failure in that carb section will starve that cylinder. Usually The operator will notice the loss of power before terminal damage occurs. <br /><br />Starvation of fuel also means starvation of lubrication and will cause terminal injury to cylinder walls and bearings if the operator doesn't intervene early enough.<br /><br />I realize that doesn't tell you what happened, but it does tell you what could have happened.<br /><br />Good luck. :)
TBarCYa
JB,<br /><br />Thanks. I never noticed any loss of power but that's mainly because I was given the boat and engine after it sat for 4 years and I've only run it for about 5 minutes since I got it.
Dhadley
If you ran it without cleaning the carbs after a 4 year nap you just answered your own question.
