Savana 2500 Rear Springs Sagging?
2broke4this
I've been meaning to ask about this for a few days, but have been afraid to hear the answer. I was under the van for an unrelated issue and saw that my rear springs seem to be sagging. They look more like a very shallow w, instead of a long single curve. Both sides are the same way. I have no idea if this is normal, but I have a feeling that it's not. The van is unloaded (the seats aren't even in it), and is a 1997 with just over 130,000 miles on it. Before I got it (about 5k miles ago), there was a wheelchair lift in it (at the rear doors, not the side), so it's had quite a bit of weight in the back for a long time. The van doesn't seem to be sitting lower than normal, but I was just curious. It sits higher than most other similar vans I've seen. It doesn't drop much (if any) when I hook the boat up to it (20 ft bowrider on a tandem trailer). Should I be planning to replace the rear springs in the near future?
It's hard to get any decent pictures underneath, but this is how it sits now:
Up close in the back:
1730V
Re: Savana 2500 Rear Springs Sagging?
The "W" may be an overload spring already. Van convertors frequently beef the springs up in wheel lift vehicles.
Silvertip
Honorary Supreme Mariner
If the springs were indeed weak the van would not sit level. In fact, your van is sitting a little bit tail-high and is perfectly normal. Don't make a problem where none exists.
2broke4this
Thanks guys, I guess I just needed a little reassurance. I don't want to endanger my passengers or others on the road. Thanks again!
-Carl
