I am about to put in a new deck on my 2000 Crestliner Rampage. Pic attached shows the hull with the old deck removed. The aluminum stringers, etc. are all welded to the hull. The old material appeared to be regular 1/2 plywood with carpet glued down. No signs it was every sealed.
I plan to redeck the boat with 5/8" BC exterior plywood and vinyl flooring (Nautolex). I am choosing not to go the glass and fabric route.
My questions:
(1) My choices for sealing the panels are epoxy resin, helmans spar urethene, or even exterior paint. What are folks recommendations? The floor on the boat was rotted but nothing I noticed structurally when I was on the water. It lasted 10 yrs.
(2) How should I handle seams between the panels? I plan to vinyl the deck with one piece of vinyl.
(3) When laying the "one" piece of vinyl should I wrap the ends of the boards? How could I even do that if the panels are already screwed into the boat?
(4) Will the screws from the panels "show" through the vinyl? I'm not sure how forgiving it is.
Thank you.
My questions:
Thank you.
