Safe driveshaft removal
mf70
As noted in http://forums.iboats.com/forum/engi...nson-lower-unit-removal?p=9361152#post9361152, my driveshaft was frozen in the powerhead. The model is an Evinrudde 4 that does not require any disconnection of the shift rod.
I forced the bottom unit apart from the powerhead, and the shaft pulled out of the waterpump - not a problem, as I had a replacement water pump kit ready. I Googled "stuck driveshaft", and the general consensus was to use a slide hammer and Pblaster. I soaked with Pblaster for about a week and improvised a slide hammer, but the shaft broke at the polished water pump seal seat.
I should NEVER have used a slide hammer!
I set up a heavy plate that bore on the crankshaft, and a second heavy plate holding two grade8 bolts. I then clamped the shaft using two 3/8 cable clamps and my 4" bench vice, and was able to jack the shaft out, under control, with no outside cracked castings of other damage.
See link for photo.
Vic.S
Your Photobucket link takes me to my own recent uploads!
