Rusted Leaf Springs & Rustoleum
summerwind1991
Purchased a used 1993 Sea Ray 17' with shorelander trailer, as I prepare for spring, doing a little maintainence, I was wondering about sanding the Leaf Springs so I can coat with Rustoleum. However I have just put new bearings in hub and have put hub on trailer.<br /><br />Will the rust debris as I am scrapping the Leaf Springs spoil my new bearings?<br /><br />Should I just pull of the repacked hub and sand with just spindle exposed?
tashasdaddy
Re: Rusted Leaf Springs & Rustoleum
you should be ok, if you did the bearing job correctly. they are now sealed. blow the debis off after sanding.
