Intermediate Mariner
Thread starter- Joined
- Apr 24, 2010
- 190
Morning Gents,
I'm the type of guy who HATES to throw anything away (look for me so join the next season of hoarders!)... I always like to think there is a fix.
In evaluating some powerheads, I have one that was locked up. After pulling head and crankcase cover I seen that there was a busted rod nut that apparently caused something to go awry. In any event it is full of globs of rust and crankshaft is rusted pretty good.
HOWEVER, anywhere you check you can flake rust off with fingernail including crankshaft. This tells me that it's just surface rust. There is also some corrosion on the cylinder walls but can easily scrape and cylinder walls feel smooth.
I'll bet the block is good and I also bet that if I soak the crankshaft in muriatic acid it'll be as good as new too.
I learned the hard way not to put aluminum in muriatic acid (it literally ate a gearcase for lunch and darn near exploded!!).
I seen that "CLR" is not recommended on aluminum but that aluminum jelly donesnt work worth a darn. Plus there is a fair amount of calcium in the water areas (this is a '61 evinrude 40 hp).
What can I soak the block in to have it come out glistening?
Can I canabalize pistons AND bearings from another powerhead and just replace rings?
Thanks!
Shawn T
Wichita KS
Thanks!
Shawn T
Wichita KS
