Running cables
lweekly
Just bought a 2006 Stinger 160. I've always had wood decks (Tracker) before and could take them off to run wires. Since the Stinger has aluminum decking, how do you run cables from the transom to the console and from the console to the bow (for a network between GPS units)?
Is there some sort of channel along the starboard side?
Thanks
BoatNoobie
Re: Running cables
If it's anything like my FM165. You can remove the panels on the starboard side. Mine are held in by a bunch of metal screws. But the thing is, 80% of the heads are stripped, so they are a PITA to remove.
I found this out when I had to replace the pitot tubing.... :redface:
