Runaway!!!!!!!!!!!!!!!!!!!!
fbjb4
Re: Runaway!!!!!!!!!!!!!!!!!!!!
tipped the floats down and seems to run fine when i trim it up and down as much as i can in the barrel. headed for the lake to see if i fixed the orig. prob of it bogging down when i open the throttle up.
fbjb4
well did the test run and it runs great to about 70% percent throttle then it starts surging. starving for fuel i assume? do i need to tip the floats back up a little? i could change the surging some by trimming the motor up a little but couldnt stop it.
bustermin
Banned
as mentioned previously, the problem is with what you have touched. you touched the carb again and changed the motors behavior. keep adjusting the carb.
