Rule Bilge float question
Speakrdude
Ensign
I've tried two of these now with the same results.
In the front of the Bilge in this 88 Sea Ray 300 WE, there is a bigle pump with float switch.
The float is factory mounted with a slight downward tilt.
The problem is, When the water level comes up, the switch kicks on, no problem, but when its almost empty and the pump is surging, the float switch wont go down enough to shut off. I first thought I had a new (bad?) float switch. Rule, kindly sent me another, same problem. Do I need to raise, lower, switch, pump, ?/
Don S
Re: Rule Bilge float question
Space it up some or angle it up instead of down.
Rule makes a clip that hooks into the slots of the bilge pump base that holds it up about a 1/2".
http://www.iboats.com/Rule-Super-Sw...2282695--**********.908502177--view_id.258950
