Speakrdude
Ensign
Thread starter- Joined
- Feb 25, 2004
- 942
I've tried two of these now with the same results.
In the front of the Bilge in this 88 Sea Ray 300 WE, there is a bigle pump with float switch.
The float is factory mounted with a slight downward tilt.
The problem is, When the water level comes up, the switch kicks on, no problem, but when its almost empty and the pump is surging, the float switch wont go down enough to shut off. I first thought I had a new (bad?) float switch. Rule, kindly sent me another, same problem. Do I need to raise, lower, switch, pump, ?/
