I have noticed water coming down either side of the outer area of the transom in my boat particully when I launch the boat. It's a 1996 Conquest 21' I/O. I am guessing that the rub rail in the back must be leaking. When launching the rear end dips down pretty far just before the boat starts floating. It doesn't seem to leak much when our running. I was going to remove the rub rail. There is a splice and cover plate on the center line of the boat on the rear and that piece runs all the way around the boat to almost the drivers seat. If I remove the rubber lining, there should be screws there right? From the inside I can see a thicker area where those screws might screw into. I was just wanted to get an idea from you guys what to expect and if you had any tips for the removing the rubber and still being able to reuse it?
Thanks
Chris
Thanks
Chris
