purplesage
Thread starter- Joined
- Nov 10, 2010
- 35
I have a new to me motor that has been sitting without running since 2002 and only had 50 hours or so on it before that. It has/had VRO and is electric start. Not sure what the previous owner had done but the VRO had been leaking for a long time so the bottom of the motor had a plastic bag around it to catch the slow leak.
Following everyones instruction I decided to rebuild the carbs even before attempting to start. It turned out the bowls on both carbs as well as the fuel filter and fuel lines were full of oil. After cleaning all that out - rebuilding the carbs and removing the VRO it was time to turn it over.
The motor started after turning over a few times but then died. I primed by pumping the bulb and started it again. It would run for a bit but then die. I then ran it for a bit by choking as soon as the RPM's would begin to slow. The motor then began to run so I thought I was doing OK but then the RPM's started climbing. I turned the key off and the motor continued to run with the RPM's increasing at an alarming rate. I then pulled the kill switch. No help. I then removed the fuel line - it took a bit but the motor did eventually die.
I started it a couple times for short periods of time - it runs but is back firing.
I obviously has cable issues but am confused by the fact the motor wouldn't quit. Do I also have electrical issues.
All advice appreciated - Jon
