fatheroftriplets
Thread starter- Joined
- Aug 9, 2021
- 1
Greetings, I have a 2005 5.7 gxi that starts and idle great. You can rev the engine at the dock so it goes up to over 4k (did not want to go farther than that without a load). When you try to get in plane, it is a little slow and tops out at 2700k. Will get on plane but that is about it. I replaced the fuel/water separator filter. I had a friend of mine check the fuel pressure. He said it was 65psi. Sounds high to me. The electric fuel pump was replaced 2 years ago. Any thoughts? (No growth on the props). Thanks in advance.
