Rough idle and other things
marklk
Hi; To start off I know about nothing about a boat. So I bought a boat and a motor. Sold the boat . When I bought it I was told the motor would run for about 15 minutes and shut down and they thought it was a head problem. I just hooked up some water to it and started it. It ran rough and died a lot. Ran better after it ran a while probably burning out all the varnish from not being ran in years and old gas. Yes, I put in new gas. So I had some questions about a few things.
Johnson model 60 1981.
1. There are water ports on both sides lower. I put muff on them and turned on water. Water did come out the small upper hole in a good stream. Water also drained out into the propeller area over the shaft. Normal ?
2. There are other ports on lower unit above the lower water ports just above propeller. No water was coming out of these. Is this normal and what are these ports for?
3. The muffs did not seal good so a lot of water was flooding onto ground . this water had a lot of oil in it. Think coming from the propeller shaft as water was leaking into that area even after shutting of engine and water hose.
4. Idled rough and could not move the throttle lever back down or it would die. I am not sure exactly where that lever should be as all stickers are gone but i can still read start and fast idle positions but whatever is back from there I can not read. It stays running for a while if left in fast idle position.
Wanting to fix this up and sell it. My thought was that the impeller was not pumping water and it was getting hot and shutting down as I see no sign of a leaking head gasket. But I do not know how to tell if that is pumping water or not with no way to actually set the motor in water.
thank you for any help
emdsapmgr
That engine has a telltale in the lower cowling. When water is pumped up to the powerhead, a simple stream of water flows rearward from the telltale- basically indicating that the powerhead has cooling water. (does not indicate that the thermostat is working, however.) If the engine does not idle well, possible that the carbs may need cleaning. Not unusual for the jets to clog up with debris over the years. Esp the idle jets. When this happens, it's had to idle. You may need to pull the carbs apart and thoroughly clean them, then reassemble. Not unusual for water to flow out and around the muffs onto the ground. Also, the exhaust is in that area and you will see a lot of unburned gas/oil mixture in that area. (it is a 2-stroke engine, so that's normal.)
marklk
Is water supposed to be leaking into the area where the propeller shaft is ? It drains out of there after shutting off water.
Silvertip
Honorary Supreme Mariner
If the engine had sat unused for years and is now running rough, it is in need of a thorough carb disassembly, cleaning, and reassembly with new kit parts. If the carburetor(s) have adjustable jets, that needs to be done with the engine in the water, not on muffs. The two ports just beneath the powerhead are called bypass ports which allows the engine to operate better at idle while in the water. A fine mist from those ports along with a slightly stronger spray is normal as speed increases. Water exits the engine through the hub of the propeller. If you plan to service this engine yourself, you really need a factory service manual (not an operators manual) specific to your engine. It saves time, frustration, and helps eliminate potential problems due to incorrect repairs.
Motor is over 30 years old.-----Possibly in very good shape too.----Before you spend time and coins you should report values of a compression test.
marklk
I have a complete service manual for evenrude johnson 1971 - 1989 1- 60 hp engines.
I was told this engine would only run in water for about 15 minutes and then die . Any idea what causes that ?
I thought impeller but it is pumping water I think since it squirts out the top port , small hole , when started but not when off with the muffs.
marklk
Well if I still own a compression tester I will do that when weather is warm again. Not sure I still own one . Most of my tools were stolen.
Might take it over to my cousins boat store this spring and have them take a look if I cant get it running good.
