Hi; To start off I know about nothing about a boat. So I bought a boat and a motor. Sold the boat . When I bought it I was told the motor would run for about 15 minutes and shut down and they thought it was a head problem. I just hooked up some water to it and started it. It ran rough and died a lot. Ran better after it ran a while probably burning out all the varnish from not being ran in years and old gas. Yes, I put in new gas. So I had some questions about a few things.
Johnson model 60 1981.
1. There are water ports on both sides lower. I put muff on them and turned on water. Water did come out the small upper hole in a good stream. Water also drained out into the propeller area over the shaft. Normal ?
2. There are other ports on lower unit above the lower water ports just above propeller. No water was coming out of these. Is this normal and what are these ports for?
3. The muffs did not seal good so a lot of water was flooding onto ground . this water had a lot of oil in it. Think coming from the propeller shaft as water was leaking into that area even after shutting of engine and water hose.
4. Idled rough and could not move the throttle lever back down or it would die. I am not sure exactly where that lever should be as all stickers are gone but i can still read start and fast idle positions but whatever is back from there I can not read. It stays running for a while if left in fast idle position.
Wanting to fix this up and sell it. My thought was that the impeller was not pumping water and it was getting hot and shutting down as I see no sign of a leaking head gasket. But I do not know how to tell if that is pumping water or not with no way to actually set the motor in water.
thank you for any help
