Re: Rotten transom (you won't believe why), how do I fix it?
I sent Stratos an email with my serial number and a bunch of pictures of the screw up. I don't expect them to help but at least they know my concern. Thanks for the good links. So is the consensus that I need to replace the entire transom wood? What is the best way to build the fiberglass up on the outside to replace the small void that will be left when I remove the cut piece? Can I just fill it with fiberglass and resin then sand smooth on the outside. Will it bond to the factory fiberglass? How do I need to prep it?
