Rot Fungus - Dangerous to Breathe?
atengnr
I opened up the floor in my boat, after years of water below, and I note that theres black spots on the hull on some of the wood. I assume this is rot fungus, and my question is, is it safe to be working around this fungus?? Is it dangerous to breathe? What precautions should be taken to safely work around and clean this fungus?
Thanks.
Happy Thanksgiving!!
Re: Rot Fungus - Dangerous to Breathe?
Ayuh,...........
I personally have Never had any sort of reaction to it, Nor have I ever heard of such a thing.......
tashasdaddy
i wear a dust mask if it is bad, and wash my hands occasionally. never had a problem.
ondarvr
Put a mix of bleach, water and a couple of drops of detergent in a spray bottle and hose it down. Use the safety gear too, but I've never had a problem.
HighTrim
It truly depends on the particular type of mould, if present. Their side effects vary. Different people also react differently to different growths. The problem with mould is that it affects you immediately, unlike other irritants such as asbestos, which affects you over a time period. A friend of mine lost half his lung to due exposure to mould, albeit a deadly mould growth under his deck , from all things raccoon urine. A fun day in the sun can turn deadly quickly. Not trying to be a grey cloud, and like stated most fungus will not immediately affect you, but if you are allergic, or depending on the type, it could. Bleach can kill some of it, although alot of times it just masks it, and the fumes can be just as dangerous. A concrete cleaner called TSP is safer and kills the growth just as well.
Solittle
Automotive antifreeze will also kill the fungus.
