boltonranger
- May 2, 2004
- 204
I've never done it but I think your line is too short; and also too thick.
The rope is pulling the can too close to the surface.
Try monofilament line. make it longer too; further from the propwash.
Also consider spacing the anchoring of the line.
I couldn't tell if the can rolled or not from the video. But you need a certain "attitude in the water" for the can to work. I suppose you could get crazy and add fins to achieve this but I thought this sounds like a simple trick that should work on it's own.
Good luck.
-br
Why would people do that?
Couldnt you just trim the motor to make a rooster tail? or how do people do it without the can?
Hi all! I've been lurking here for quite a while.Great forum you have here,I've benefitted many times from all your advice and information! I fish the Illinois river,in my 14' Lund..
I just registered so that I can tell you what I saw yesterday. 4 young kids drifting in the middle of the river,very nice boat,big outboard-
I heard a motor screaming and looked over to see what was up.-The motor was up!!!! They had tilted the motor so the prop was barely touching the water,to shoot a rooster tail about 20 feet high! That went on for well over a minute,then they shut it down,laughing and screaming like idiots.
2 or 3 minutes later,they did it again! I had to look away the 2nd time.
It's been quoted here before though: 'so what,daddy will just buy me another motor!"
Ok im really bored atm heres a diagram, im sure it would be much heavier than a tin can depending on how you made it, man i need to get out and try it myself haha!
12-24" of 3" Pvc, 3" to 1" pvc reducer 2" of 1" pvc, pvc 45 degree coupling, 6" of 1" pvc
If you make the thing big enough it you should be able to cut it down if need be. Anyone remember building potato cannons? It should funnel the water into the 3" section, compress the crap out of it then send it flying out the 1" end at high pressure.
*Note* Seems like tossing something out the back with boat already at speed would cause a major jerk on the string or whatever was attached to the can/tube. If it did grab and the string wasnt strong enough it could just break off :\
