hkeiner
Thread starter- Joined
- Oct 17, 2006
- 1,055
I have read about one troubleshooting test where you pull the spark plug wire (one at a time) from the spark plug while the engine is running and monitor what happens. If the motor idle speed drops uniformly for each spark plug wire pulled (cylinder), then that is a good thing. If the idle does not drop for any particular spark plug wire (cylinder), then that my indicate a problem on that cylinder. This test makes a lot of sense to me. In contrast, I have read elsewhere that it is very important to ground spark plug wires when they are disconnected from the spark plugs and you are turning over the motor. This is often mentioned when directions for performing a compression test is given. I presume that this caution is given to avoid damaging the ignition system.
The directions for the above two tests seems to be in conflict with each other regarding the grounding of the spark plug wires. Since I plan on performing the former described test for the first time, I thought it best to better understand the techinque and risks to the ignition system when pulling spark plug wires while the motor is running, if there is any. Also, how do you best avoid getting a jolt when handling the wires.
Thanks in advance for any thoughts on this.
