FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
1999-2000 model motor will not shift into or out of gear when left outdoors in temp. below 30 degrees overnight. Does not have water in lower unit. P roblem can be solved by heating lower unit with blow dryer for about 10 minutes.
Rick is right. Should still shift. Maybe some water laying around the rubber grommet that the shift rod goes through in the midsection, freezing up around the shift rod.
