crazy charlie
Thread starter- Joined
- May 22, 2003
- 5,749
Check out the pic.Hard to see but the riser hose has a bit of a restriction against the lift plate.
Not sure if that is what it is called.New to me 5.0 used motor that I got in a pinch when I found my stbd motor was in a bad way.The riser hose has a slight restriction against the plate.My neighbor pointed it out to me .He is an auto tech that builds race cars from scratch so he knows his stuff as far as cars are concerned.He suggested to cut the hose at the pinch and add a rigid piece(pipe) to the hose to eliminate the pinch. Seems to make sense to me.Or should I dremmel off part of the plate that is creating the restriction.Not overheating .RWC with alpha drives.Should I be concerned?? Charlie
