Ring Free Results So far
MickLovin
Master Chief Petty Officer
Hi, after using ring free for about 1 hour at 2 half intervals, I have found that so far my motor is idling much better and it has spat out a lot of black crap from the exhaust. The spark plugs are still fowling but this may be due to ring free still in the system as a shock treatment, It has been a lot easier to start now from 20+ pulls to 3-4. I still have to do a compression test, but as mentioned on a previous post my compression started at 120psi bottom cylinder and 135psi top cylinder. So I will post more results (compression etc) from my experiment with an old motor and Ring Free after running my whole tank with it in through my motor. Already I have noticed the results! :cool:
boobie
Re: Ring Free Results So far
If it's helping it, do it again and one more time. Maybe more.
kfa4303
Banned
+1. Be sure you get the motor up to speed on the water for a while too. That will help raise the engine temp and burn off any excess/leftover ring free. Glad it worked.
