nola mike
- Apr 22, 2009
- 6,060
Took the boat out today, noticed it was smoking at idle, maybe running a bit rougher than usual. Opened it up and noticed it was slow, maybe 38 or so instead of 48. Rpms were 4300 with 2 aboard, usually 4500 with just me. In fact, speed was down over the entire rpm range. At idle, I noticed a bit of fuel leaking out of the venturis with the butterflies closed--I assume that's abnormal. So I took it back out at 4k rpms for 2 miles or so, and killed it and checked the plugs, which were black.
1. Does a few drops leaking at idle mean that I'm running rich across the board?
2. If I wasn't rich @ speed, should my plugs have cleaned up during my high speed run?
3. is a rich mixture enough to cause that dramatic loss of speed? It ran fine at higher rpms. I would have expected a loss of rpms as well.
What's the problem with the carb? Leaking needle valve/poor float adjustment? it's run fine all summer.
