steve6
Thread starter- Joined
- Aug 14, 2009
- 70
i just took my boat out to switch trailers, seems reverse does not work. forward was fine for the quick drive around the launch area. I brought and checked some online stuff, said put it in gear and turn the prop. When i do this it does not turn the engine, I can sorta hear it trying to engage(forward is fine). When I started it up out of the water, and put it in reverse nothing, I rev'd it up a bit and it would turn the prop a bit, doubtful its not being engaged properly.
could this simply be cable adjustment? or clutch dawgs? anyone have a manual for this engine? exploded view of the bottom end , can I just drop the lower unit and check this, or does the lower unit itself need to be taken apart? Not entirely sure of engine year, its mid 80's (no oil injection).
please help!where should i start? reverse is nice to have
-steve
-steve
