on muffs, the 100 could be as high as 3 or 4 psi; which now makes me think that the Tstat is stuck open. What they lack in water quality is made up in pressure! 115 is still on its stand, but hooked it up for preliminary testing. On muffs, no pressure, water came out port side exhaust and trickled out starboard side.
Spun it with the starter, engages well but not releasing. 1000 amp battery was showing 12.4V but load test showed on the line for weak. Been charging it every week or two for awhile now????? Most likely need to work on the starter some. Gotta love that Lectric shift prop spin!!!!!! Was really good to see that!
even though she's not quite ready to fire...
Spent most of the day chasing the water problem. Backflushed the motor, changed the intake hoses from the housing to heads, have water coming out both sides of housing, but not enough pressure to fill the block and exit from the top of head? Might need to be running? Couldn't separate the housing to investigate and I tried! You'd think with that much water pressure... maybe not? Leave it alone???? and just be cautious - closely monitoring temp upon first start up. Or maybe fix starter, spin it, and see what I have then?:help:
And I have a leak from the bolt holding the guide bar for wires to the spark advance and ground wire - goes into the top water jacket, no big deal...
