Request for information: Livingston 19.5 ft, Cuddy, MerCruiser
Hound13
I just bought a 19 ft, Livingston cuddy with a 305 Chevy, and MerCruiser alpha one.
I can not find a THING on this boat.
Specs.
Wiring diagram.
What it actually is; registration says 1991.
Is it a 305 Chevy?
How big is the tank?
I know that it's a project. I know it has some issues but it also has a lot of potential.
Anything anyone has would be appreciated.
briangcc
Wiring diagram - no likely to be found, probably never existed.
Whatever your title says is what it is.
IF your engine is a 5,0L then its a 305 cui. Going off the age, Chevy block.
Tank size....empty it completely then fill - most accurate way to determine this as given its age it *might* have been replaced and *may* not be the original size.
You can get info on your motor and drive based off the serial numbers. Factory manual will have motor related wiring schematic
As stated above, wiring info for boat most likely doesnt exist as boats are generic and most boat manufacturers do not document it
When you pull the tank to redo the stringers and bulkheads, measure the tank
