repowering - transom build up
redtailedboa
I have a 1993 checkmate Predictor with a 115 merc on it. I need to know how to make my transom stronger because I am putting a 225 evenrude on it this summer. Any help would be great. Thanks
QC
Re: repowering
Re: repowering
Welcome aboard redtaildude!! I have moved this over to the restoration section as these guys love playing with transoms . . . ;) I am going to add that to your title as well to give it some focus for this section.
ddrieck
Re: repowering - transom build up
redtailedboa,
First.....Welcome to iboats.....You will find a wealth of information on this board.
Ok...lets git at it. First thing everyone is going to ask is, "What is the max hp your boat is rated for and then everyone is going to want pictures. With that being said, You should get the max hp rating and post up some pictures of what you are dealing with.
redtailedboa
My boat is only rated for a 125hp but I saw several on the lake this past year and not one had anything lower than a 150hp. I will get pics up asap.
Ayuh,... Just how Big is this boat,..??
Will the hull support the Weight of that 225,..?? Just sitting at the dock, not moving,..??
Just a Guess, but I'd think a Backwash is gonna Swamp it....
erikgreen
Not really a good idea... despite the fact that the boat will take the weight, at least if you adjust your ballast some, that's way too much power.
I'm not saying it'll be uncontrollable, or hard to drive (or not fun) because that's not the issue.
It's a big risk for another reason... a legal one. If you get in any kind of accident at all.... like a drunk boater with four kids steers out in front of you while you have the right of way, you stop completely to let him pass and he turns and rams you.... it'll be your fault.
The courts take a very biased view toward overpowered boats.... putting that much more power on a boat than a manufacturer rates the hull for will get you a very fast hull that could end up costing you everything you own.
Bottom line, if you want to get a faster boat, then get a faster boat... don't try to hop up the one you have.
To answer your actual question, yes you can reinforce the transom to take the 250... but you'll have to rebalance your whole boat so it floats level with the new weight. You'll have less freeboard and take more water over the sides.
Also, the power a boat is rated for isn't related to transom thickness... it's more the hull shape and weight. So even if you make the transom strong and rebalance the hull, you could still end up with an uncontrollable boat, because the person who designed it didn't think it'd ever go that fast, and it's designed to be most smooth and maneuverable at a certain speed.
Think of it this way... your average luxury car has maybe a 300 horsepower engine (on the high end model) and steers very smoothly and easily. If you put a 600 horsepower engine in it, it'll go faster, but do you think it'll be easier to control? Or even feel as stable and smooth as it would at 300?
There's a reason why Ferraris have fancy suspension and controls, and it isn't so they can charge more...
Erik
