Repower to Later Model
Reel Kahuna
I have a tired Volvo 130 and 280 outdrive on my boat so thinking of repowering to a later model ( maybe Merc) motor and (Alpha) outdrive. Is that do-able with little transom modifications?
NO. your stuck with a volvo AQ series to fit the hole.
Reel Kahuna
That's what I was afraid of. I might as well patch that hole and hang a 50-70hp 4 stroke. Thanks so much for your reply.
Seon
they made the AQ series up until the mid 90's
get a V8 and duoprop drive, drop it in and go boating.
Reel Kahuna
I'll use the boat as is for now and search for a replacement later this year then I'll have a winter project. Thx
Chigwalla
What shape is your transom in ?
It would be a shame to hunt for something to fit the hole, only to find when you get the old transom assy out that you need to do the transom.
That would open up more power options for you since you'd be cutting a new hole anyway.
Reel Kahuna
What's the total weight of the Volvo 130 and 280 outdrive?
QBhoy
If you can find an AQ205 VP and decent 280/290/290dp, you would be right.
The AQ205 or 431 is a great motor. V6 MG engine with the quadrajet 4 barrel carb. Produces 205hp which is only slightly less than the big v8's of that era did....and a fraction of the weight.
