longshanks
Thread starter- Joined
- Jun 12, 2006
- 188
After trying a number of props, I've found a Quiksilver / Mercury Vengeance SS, to be the best performing prop for my setup. However, WoT RPMs are too high
- Mercury 50HP 4-stroke EFI, tiller handle. Recommend WoT RPMs 5500-6000
- Quiksilver SS 11 5/8 by 11 Pitch prop
- GREAT holeshot, 31 mph top end, but easily reaches 6000RPM, and alarm goes off at 6200, and motor feels as if it may wind out a little further.
- heavy aluminum boat with 6 degree bottom, 15', about 1300lbs w/ motor. Motor is raised to maximum height possible.
I plan on keeping this prop, because it performs so well with a load, and it could be used for wakeboarding/skiing. But I'd like something that could be used for cruising, that won't over-rev the motor. Any suggestions on what I should look for?
I'm thinking that a 12-pitch should do the trick. Will a turning point hustler aluminum prop perform as well as my SS prop, in terms of speed and RPMs? Or should I stick with stainless?
cheers
Shane
cheers
Shane
