Replacing upper outdrive
sptjet90Reflexx
So upon removal of the top cover on my alpha one gen 1, 2 bolts snapped inside the case. For the price of paying a machine shop to remove them I already ordered a re-man top unit.
I will reuse my lower unit as I already replaced the water pump and it has less than 5 hours on it.
What specific gaskets will I require for the lower end? I believe it was just the oil o-ring?
Also what gaskets will I need for the top to go back into the boat?
Thanks for your time as always :)
sptjet90Reflexx
Re: Replacing upper outdrive
That kit had dates for 1967-1982? my unit would be 88
Ayuh,.... I use Sierra 18-2619-1, which is for the Gen.IIs, but works just Fine for All of the Alpha series drives, from the MC-1, through the Gen.IIs,...
sptjet90Reflexx
This kit did not come with an O ring for the lower to upper oil passage?
achris
More fish than mountain goat
Then reuse the existing quad ring (it's not an 'O' ring), if it's in good condition. If not, just buy a new one.
