Replacing Trim Hydraulic Hose and Oil
munn_2003
Hey guys,
I have a 1980 Mercury Blue Band 850 Outboard motor with Hydraulic Trim. One of the hoses has broken and all oil has come out. I have a replacement hose but was wondering the best way to replace the hose and oil simply and safely without causing damage? Also which oil is recommended?
I have got photos if needed.
Thanks
Munnaz
Re: Replacing Trim Hydraulic Hose and Oil
Ayuh,... Remove the old hose,... Install the new hose,...
Fill the pump with ATF,+ Run it up,+ down, repeatedly, keeping the pump full of ATF...
It's self bleeding...
