Finally starting to replace the transom on my 1994 Lund. Fortunately I have 3 people helping me. All three are a lot more mechanical than me and one of them replaced his transom before. First day we pulled the motor and dug out the old transom in about 5 hours. Fortunately I did not have to remove the splash well but did have to cut a hole to get to one of the tow hooks. I guess I should say we vacuumed most of the transom out because it was pretty bad. Lucky my 115 hp motor did not fall off. We made a template out of thin Luan. My nephew has a 1" Cement Form Board left over from when he did his transom. I am going to buy 1/2" Marine Plywood because my haul was 1 1/2". I am planning on screwing the boards together with 1 1/4 coated deck nails. My question is, Should I also glue the two boards together and if so what would you recommend? Also, I am assuming I should coat the edges of the two boards. Was thinking about using Marine grade below the water line epoxy. Good? Thanks in advance for your advice.
