Replacing thermostat on Mercruiser 470
mk160
I need to replace the thermostat on my Mercruiser 470 (4 cyl, 224 cid, 165 HP). The engine SN is OB749835. I have the thermostat replacement kit, exhaust manifold (sierra 18-0956-1) and elbow gasket (sierra 18-0113-1) on order. Any lessons learned or advice out there? Thanks!
jhamblett
Pretty straight forward , I just did mine although the engine was out of the boat. I am in the middle of a alternator conversion so I had the tube off the thermostat to access the voltage regulator easier and to flush the coolant
mk160
Thanks! Looks like four bolts to get the reservoir off and then the manifold. I did my alternator conversion about four years ago, still have my stator!
jhamblett
Wish I had the room to mount my alternator to the side. Mine will have to be up higher.
mk160
Jhamblett I just looked a little more closely at your second picture. It appears that the thermostat is at the front end of the exhaust manifold and that I should be able to replace the thermostat from below without removing anything?
jhamblett
Yes you should be able to. Socket with a flex joint
mk160
Thanks, did not know that. I'm assuming the previous owners had an issue with the stock filter. I'll see what I need to do to replace it.
