daniel9829
- Feb 18, 2011
- 6
Thanks Guys you were a great help in rebuilding a 74 Sail boat and now I have another project boat. It is a 19 ft Cajun 1900 ultra. it has some soft spots in the floor and I am going to pull out the console this weekend and get into the floor and check the stringers. I need to know a couple of things. What thickness will I need to replace the floor I was thinking 1/2 or 3/4 CDX wrapped with fiberglass and did not know which would be better. Also, The foam in the bottom is most likley wet also and I need to pull it out and replace it. Any suggestions on what foam to use. I searched foam and cam up with enough to confuse. Thanks Danny
