Replacing stringers in a fiberglass boat
Woodonglass
Buy a large tarp to cover the boat use heat lamps under the tarp make sure your resin is at the same temp as long as you can keep the substrate and resin above 60 deg for a couple of hours it'll cure just fine
Mithories3980
i figured that would workout ok. Well, I think I have everything figured out for now...I've figured out the products I need and found a video series on YouTube of a gentleman doing the EXACT same project as me. In fact I think one of you guys suggested him after I found his videos. Its starting to get cold now, and my job is busy in the fall so I probably wont be getting much done until winter or next summer. But, I have a LOT of cutting to do yet :rolleyes:
I think this is the last thing I need to really know..... Do you guys have any suggestions where I should order my fiberglass supplies from?
I appreciate all your input! Thanks guys!
Baylinerchuck
Fiberglasssite is another good place. I used all their materials in my build, with the exception of the pour foam. I never found a cheaper place than US Composites.
