Replacing stero can I use existing remotes on transom and dash??
rsidwell79
I am upgrading my head unit but I wanted to leave the existing remotes on the transom and dash. If I stay with a Calrion head unit (that is what is there currently) will the remote cables be compatable?
Thanks
Silverbullet555
Re: Replacing stero can I use existing remotes on transom and dash??
They most likely will if your head units have wired remote inputs. I would double check first to make sure the head unit you choose is compatible. The documentation should mention it.
Auger01
What do you have and what do you wan to put in? There is a chart on the Clarion website somewhere that shows what is compatabile.
rsidwell79
I have a XMD2 that quit working after I hooked the battery up backwards. I blew the 90a main fuse but I guess that didn't protect the radio. I want to put a M109 in to replace it. Appreciate any help!!
rsidwell79
The M109 is not wired remote ready, so maybe the M303. It looks like I have to change the remotes.
