Replacing Impeller on Alpha 1 Gen II
MarkSee
Re: Replacing Impeller on Alpha 1 Gen II
I do have question, is QuickSilver the OEM?
Yes. Quicksilver is the "branding" name where you can buy the same stuff at non-official 'Mercury' labeled dealers.
Check the part numbers on many items between Mercury and Quicksilver and normally just 1 character difference.
Go to a 'Mercury' dealer and you'll see both 'Mercury' and 'Quicksilver' branded items. Go to Walmart and you'll only see Quicksilver.
Mark
achris
More fish than mountain goat
Thanks for the link Chris. I was not planning on buying online, I was planning buying from my marina. I support my local small business. I was just wondering if there was a difference in quaility over aftermarket and OEM. I do have question, is QuickSilver the OEM?
Very much yes.... That's why most people who do their own work (and actually care about what they do) use OEM.
Chris.........
waterdowg
I purchased a Merc OEM impeller today from my local marina. I opened the package and read the directions and now I have a question. They conflict with Don's instructions. I do trust what Don wrote and will follow his directions. But my question is with the Drive shaft seal. Don says to pull the drive shaft up while pushing down the seal. Now the Merc directions say make sure the drive shaft is fully down. Whats with that?
achris
What exactly do the Merc instructions say? The correct method is to pull the shaft up, and that's what's in the Merc manual...
Don S
Odd, Merc doesn't include instructions with their impeller kits that I am aware of. Scan or post pictures of these instructions.
sean.deangelis
Doesn't matter... Even if you put it in the wrong way. The long vane impellers just flip over the first time you turn the engine... No harm done. Think about when you put the drive back on, you turn the propshaft CCW with the drive in forward. That turns everything backwards, and flips the impeller blades over... Then you start the engine, and the blades go back the right way... :D
Chris......
123
MarkSee
In the 817275q05 kit that I had purchased and used in my Maxum over a year ago, there is a parts list and set of instructions that is document # 90-898101906 dated June 2007. But right there on page 6, step 5, it not only says to pull up on the shaft while pushing down on the face seal tool, it has a picture with an arrow showing it.
As indicated, OP will need to provide some info on what he's looking at as it's not matching what I'm looking at.
Mark
achris
Negative. I believe no matter what direction you turn the final shaft on the outdrive the impeller continues the same spin as the engine. Final gear transfer is before the prop shaft.
Seriously?????
ktbarrentine
Chris: I guess you can try to explain this concept to people all day long, but some will only actually see (and "believe") what you are saying when they have their drive apart and play with the rotations (i.e, rotate the prop CCW with the shifter locked in F, impeller rotates CCW-looking down on impeller; rotate the prop CW with the shifter locked in R....impeller rotates CCW). Your explanation is clear and accurate to me.
Don S
FYI: I did not write that, All the information in that file came from pages in the OEM service manual. All I did was put them together in a single file to make it easier to get to.
fishinrado
Thanks for the write up, doing mine for the first time as we just bought the boat late last fall......does it matter what gear you start he procedure in? I've done other boats of mine in the past so it all looks pretty easy.
but what does this mean "Clamp the unit on the gear housing anti-ventilation plate in a suitable fixture".
Also do any of these seals have anything to do with hydraulic fluid leaking out of weep holes or is that a completely different seal? having trouble locating that info! Want to do it all at once.......read all the stickys but don't see it.
Don S
You need to ask your questions in your thread fishin, this thread is for waterdowg's questions and answers.
fishinrado
oh I though this was a community gathering like all the other forums I am in ?????
everybody chimes in to all the threads I've read as to the pertinence of the topic so not sure
what you are saying
Don S
it gets really confusing when two people are asking questions in one thread. Pretty soon we loose track of who is asking what and who is answering whose question.
So what we do on this forum is people ask questions about their problems in their own thread.
There is an announcement at the top of this forum explaining it, along with our forum rules.
fishinrado
no problem........I have been on here off and on with several different boats/engines
for a few years so I appreciate all the info :)
waterdowg
I'm going to read the directions again just to make sure I didn't mess that up, But pretty sure it said make sure the drive shaft is all the way down. I will can the directions and post on Monday. It was a single page with print on the front a back. I went to the Merc Dealer and have them the QuickSilver kit number and they only sold OEM so thats what I got.
waterdowg
Ok I took a few snap shots of what I bought and a shot of the section in the directions I'm questioning. The date on the bottom is April 1994. I can scan the sheet tomorrow and attach it here.
MarkSee
That document is old and outdated honestly.
I scanned a couple files from the documents I have dated June 2007 and July 2008 but the size was too large for me to attach here. Here's a link to service manual 14 page 3b-77 and it is even underlined about pulling up on the shaft.
Boatinfo - Mercruiser Service Manual nr. 14 - 1991-Current - Sterndrives Alpha One Gen II</
What you see in the link is what each of these documents say also.
Mark
waterdowg
Interesting that its an old document. Should I be worried that the part is old as well?
