I need to replace the impeller on my 2003 Alpha 1 Gen II. There seems to be a good video on the Web on this I just wanted to know if this was correct or if the video is missing some steps, or if things can be done better. I did notice in the video that the person did not use the alignment pins. But instead put the impeller in the aluminum housing and then placed the impeller and housing on the shaft. Also the person in the video used WD40 alot. Will that eat away at the impeller?
Part one:
Replace Sea Pump Impeller on an Alpha - Part 1 - YouTube
Part two:
Replace Sea Pump Impeller on an Alpha - Part 2 - YouTube
Thanks,
Phil
Part one:
Part two:
Thanks,
Phil
