Re: Replacing flooring and carpet
I have just done my 1984 Bayliner Capri in the same way. Due to a torn cover, the PO had allowed a section of floor to rot from the top down - so after checking the foam (dry), stringers (dry) and transom (dry), I chopped out the rotten section and replaced with a piece of 1/2" ply.
I rubbed down the old paint/resin from the deck and then gave it a liberal brushing with poly resin. That dried overnight and I then laid a layer of CSM with poly resin. I left that to harden for a couple of days and then sanded it with 180 grit (with a respirator!!!!!!) and then laid a layer of mat down with clear epoxy. I then sanded and added two more coats of epoxy - this sucker is waterproof and resistant to anything I want to throw at it.
I left a couple of days for everything to fully cure.
Despite the negatives towards carpet, I wanted to use it so I cut my carpet about 2" oversize and used a waterproof carpet glue. This goes down with a spreader and has a good wet tack - basically it holds the carpet while wet and then forms a rubberized flexible bond. After about 2 hours I could push the edges of the carpet into the corners and trim with a very sharp carpet knife, replacing the blade edge every 6' or so.
I'm really happy with the result and the carpet is really stuck down after a couple of days to dry.
