fastempo
- Nov 2, 2010
- 32
Unless I'm missing something, there is no escaping separating engine from forward motor mount when installing a new fan belt on '73 3.0- 140 mercruiser engine. This will of course require the engine to be temp. supported some way, so fan belt can be slipped past this joint. Is it better suspend the engine from forward lifting eye, or to block it to hull from underneath? Any advice would be greatly appreciated, thank you. U3.
